Where is Add CID Rule
Discussion in '3CX Phone System - General' started by felipeg007, Jul 19, 2016.
  1. felipeg007
    Jan 28, 2015
    18
    I am looking for the Add CID Rule for Inbound Rules - Routing incoming calls.
    It is described here:
    http://www.3cx.com/docs/manual/inbound- ... vorfngfl2b
    “Add CID Rule.”
    I have looked on both version 12.5 PRO and 14 SP3 PRO and can not locate it.
    I am trying to route calls based on Caller ID.
    Thank you
    Felipe Garcia
    Wilson Sporting Goods\Amer Sports America's
    10,375
    231
    Did you try...
    Select Inbound Rule, from left column
    Click "Add DID" from the top menu
    Under Number Mask, Inbound Rule Type...use the drop-down menu and select Caller ID Number/Mask
    It could be slightly different depending on the version you are using.
  3. felipeg007
    Jan 28, 2015
    18
    Yes i tried this under Inbound Rules:
    "Inbound Rule Type" Caller ID Number/mask . For anyone else looking for this. this works but the rule needs to be above all your DID rules.
    Thank you
