Where is Server Activity Log on Disk ?
Discussion in '3CX Phone System - General' started by BobD, Jul 25, 2011.
  1. BobD
    Apr 25, 2011
    27
    IMO, the Server Activity Log is way to small to view via Web Interface.
    I'm glad there is [X] Keep Backup of Log File but can't find where it's put them.
    It's not doc'd in the manual and the (?) is just repeating the label.
    Another thread mentioned %AppData% but that's environment variable specific to the logged in user.
    Can anyone tell me where the disk log files are stored?
    Thanks,
    Bob
  2. willow
    willow Member
    Mar 1, 2011
    471
    C:\Documents and Settings\All Users\Application Data\3CX\Data\Logs\Backup is this it
  3. BobD
    Apr 25, 2011
    27
    Argh and Thanks!!! I found the logs!
    has Deny List access for even Administrators. No wonder I couldn't find them.
    I have 3CX installed on Windows Server 2008 R2 Foundation. Seems like that root was replaced with:
    C:\Users\Public\
    in more current OSes.
    Bob
  4. ChrisHerrmann
    Jul 13, 2017
    8
    Looks like current nix is: /var/lib/3cxpbx/Instance1/Data/Backups
    other useful logs etc under /var/lib/3cxpbx/
