Where is the calls database file
Discussion in '3CX Phone System - General' started by amygoda, Jun 29, 2008.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    anyone know Where is the calls database file
    Thank you
  2. francesco
    francesco New Member
    Jun 23, 2008
    102
    Postgres DB is on port 5480 and super user name and password found in C:\Program Files\3CX PhoneSystem\Data\Http\functions\data.ini (use db_sys_user and db_sys_password). This include call-table
  3. SIPfun
    Jun 23, 2008
    56
    Did I read somewhere that Access can read this???
    I've developed apps before that use the jet engine to read/write/create/etc "Access" databases... Is it that easy?
  4. francesco
    Jun 23, 2008
    102
    there is an application for this in Access:
    3cx call reporter
