Where is verbose logging in v14?
Discussion in '3CX Phone System - General' started by aberry, Oct 14, 2015.
  1. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    So, the default activity log for me in v14 is defaulted to verbosity level 2... So basically no useful information. I had to go into custom parameters and set verbosity manually to get it to a higher level. And the full verbose button at the top of the log is gone? I don't have any problem with changes, but don't understand this one. Hopefully this will be helpful to others who have upgraded.
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    In V14 you just need to go to Settings > Advance > Logging Level and adjust log level "on the fly" when needed which will automatically set logging from Low -> Medium - >Verbose.
    Yes we removed "Verbose" check-box because you can just download "3CX Log Viewer" from Help> Download 3CX Log Viewer
