Where is VoiceMailBox?
Discussion in 'Windows' started by dumbblonde, Mar 31, 2011.
  1. dumbblonde
    Mar 30, 2011
    Hello, I'm new here and so confused... :)
    I have downloaded 3cx version 9 & softphone. I'm the only user so there is need for only one number actually which is now connected to the system. But how can I record my own outgoing voicemail? I haven't even found the VoiceMailBox so I'm totally lost. I hope somebody can help me. Thanks.
    10,586
    252
    Did you download and read the extension manual? If your have chosen to use 3 digit extensions, voicemail access will be 999, as the default. There options are in the voicemail menus to record a greeting, also in the manual.
