Where is Windows Installer 4.5 per win 2008 Foundation ??
Discussion in '3CX Phone System - General' started by MasterX, Sep 29, 2011.
  1. MasterX
    Oct 2, 2008
    28
    hi,
    a pre-requisite for version 10 is windows installer 4.5
    i go at this url http://www.microsoft.com/downloads/it-it/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4 but not is nothing ?
    where is Where is Windows Installer 4.5 per Windows 2008 R2 Foundation ??
    thanks
  2. paul1
    Jan 14, 2010
    80
    Re: Where is Windows Installer 4.5 per win 2008 Foundation ?
    I know the pre-requisite applies to the MyPhone portal local install. I just installed 3cx PhoneSystem on Win 2008R2 Foundation and it did not ask for the installer. Either it is already present or not needed.
