Where to find SP1 for v15
Discussion in '3CX Phone System - General' started by Ben C, Sep 29, 2016.
  1. Ben C
    Oct 14, 2014
    71
    I have installed V15.0.0 for testing purposes (3CX Phone System PBX Edition). Later we will upgrade from v.14 to v.15.
    I have read people saying they are running V15 SP1. How come SP1 is not included in the 93 updates I see in the 'update page'.
    Please see the attached pic. What am I missing?
    Thank you
    Ben C
  2. travstoll
    Jul 11, 2016
    11
    If it doesn't show an update, you are probably on sp1. To verify go into parameters on the settings page. I believe the full version number for sp1 is 15.0.57336.0
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
    Actually you can view this from the dashboard. Under the information section next to the license it says activated and the version number next to it.
  4. Ben C
    Oct 14, 2014
    71
    You are right, Dashboard -> Information -> Licence: Activated PBX 15.0.57336.0
    But, Settings -> License Settings -> Version Number: 15.0.0 !!!!!
    Thank you YiannisH
  5. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
