Which Android smarphone supported by 3CX
Discussion in '3CX Phone System - General' started by josephnguyen, Jun 8, 2014.
  1. josephnguyen
    Jun 8, 2014
    I íntalled 3CX system 12 service pack 5 on window server 2008 R2.
    My client use android smartphone such as galaxy note 2, note 3... fw 4.x.x
    But the call very bad
    I dont know unstill 06/2014 which android smarphone or which firmware of android supported by 3CX.
    Please help me.
    Many thanks
    10,371
    230
    At the top of the Android section of the forum there is an old post, listing the "supported" devices. Sadly this is a few years old and has not been maintained.
    One of the problems, these days, is that there are so many variations of Android devices out there. Even on the same model you can have a different version of the operating system , not to mention "custom software", or restrictions, that are imposed by some providers that "give" you a phone/tablet when you sign up for a mobile plan.
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Try disabling some of the codecs and play around with which one works best.
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Try also csipsimple from google play, uses less battery and works stable.
