Which BRI Gateway would you recommended?
Discussion in '3CX Phone System - General' started by ziptalk, Nov 16, 2008.
  1. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    I have installed 3CX on our network, and have a spare ISDN 2e available for testing. We have had various experiences with VOIP, initially with a hosted-VOIP solution - but we realised that despite an SDSL line, QOS-enabled Cisco switch and the like, VOIP seemed inherently flakey from a external call point-of-view and was unacceptable with our customers. (We're an IT Support company). We brought our PBX inhouse with a Nortel BCM-50, and used standard ISDN 2e to break-out to the PSTN of which ISDN proves solid as a rock both in terms of reliability and quality. Therefore VOIP on the LAN was fine, but breaking-out to PSTN for external calls was the only acceptable configuration for it. What frustrates me with the Nortel, and the Avaya-kit alike is their proprietrary nature, licensing costs etc, therefore I have been tasked with investigating an open-source solution with the view to have a cost-effective solution both in-house and ultimately one we can package and supply to our existing customers.
    I want to replicate our current setup with the 3CX, i.e. have PSTN via ISDN 2e. I have opted for the 3CX, primarily because it's Windows-based and that's where our strengths lie, the Linux-based Asterisks/Trixbox would have involved an investment in time that we do not have at present.
    Having looked at the supported digital gateways for the BRI interface, it seems that the MediaTrix, Patton and the Vegastream seem to be the likely options. The MediaTrix seems incredibly expensive, the Vegastream is more reliably priced.
    • Has anyone setup their 3CX in such a configuration with ISDN 2e?,
      and if so which Gateway have you used and/or which would you recommend ?
      Also is there any reputable places to buy this hardware at reasonable prices ?
    Thanks in advance,
    Lewis
  2. cs
    cs
    Sep 18, 2008
    27
    we are using the pattons - great devices
    how many BRIs (internal/external) do you need?
  3. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Hi CS,
    Thanks for the prompt reply, in answer to your question I only need a single BRI interface, as this setup is for testing purposes so i can demo it to the business as a working solution.
    The Vegastream Vega 50 Europa Gateway 2 x BRI 4 Channels is the device I was considering at £499 ex VAT.
    http://www.voipon.co.uk/vegastream-vega-50-europa-gateway-2-x-bri-4-channels-p-410.html
    However I have just had a look at the Patton, they're a lot cheaper (I like that), and this one is £195 and would suit my purposes.
    http://www.voipon.co.uk/patton-inalp-gateways-patton-isdn-bri-gateways-c-3_122_123.html
    Lewis
  4. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Hi Lewis,
    Drop me an email on Monday, as I can probably beat VoIPon's prices on Patton stuff as we're a UK reseller (and for Snom/3CX as well).
    Cheers,
    Mike.
    michael.knowles@pentangle.co.uk
