Which code can be used for forward all calls temperarily?
Discussion in '3CX Phone System - General' started by gordontor, Oct 10, 2013.
  1. gordontor
    Jul 6, 2013
    14
    And which dial code can be used to cancel the forward?
    Thanks.
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Re: Which code can be used for forward all calls temperarily
    That's the "Emergency Code" you would set.. to force Out of Office for the system.
    Set that in Settings: Advanced: Dial Codes.
    There is some help context on using it as well.
