Which Event Log Messages are Important?
Discussion in '3CX Phone System - General' started by msauer, Apr 2, 2015.
  1. msauer
    Mar 15, 2013
    10
    The 3CX Event log lists a lot of Informational and Warning messages. I have looked up the Event Id's as the forum gives several lists with a brief explanation, but the description does not tell whether or not it is important, or if something can be done to correct the issue, and what to correct. I am not a novice, but the Event ID's are specific to 3CX and the answers do not seem to be there. The ones that I get often are 12289, 12294.
  2. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Did you see this list?
    http://www.3cx.com/blog/docs/list-of-events-generated-by-3cx-phone-system/
  3. msauer
    Mar 15, 2013
    10
    I did see that post and a few others, they all say the Event ID and a brief description. Again, I wish to know which are important ID's to pay attention to and how to resolve them if they are. Web searches also do not seem to describe resolutions, only a description.
