Which FXO to recieve incoming calls?
Discussion in '3CX Phone System - General' started by cevatkerim, Jan 20, 2008.
  1. cevatkerim
    Jan 20, 2008
    14
    I'm stuck between HT-488 and Linksys 3102. Which should I use to get incoming calls? Which one is better overall?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Re: Whish FXO to recieve incoming calls?
    HT488 is very easy to config. However, it cannot decode incoming caller id from PSTN.
    SPA3102 should sound good. The sound quality should be better than HT488 as well. Its caller id function is also stable. However, the price is higher than HT488.
  3. cevatkerim
    Jan 20, 2008
    14
    I use different PAP2s and I really like their voice quality. I just want to get incoming calls thru 3cx. Caller id is a plus so should I get Linksys 3102?
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    If you preferred incoming calls with caller id. HT488 unable to help you. It officially not support caller id from PSTN.
  5. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    The lynksys 3102 is very easy to set up, I have 2 working fine and got them up and running in minutes
  6. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    yes, i also prefer the linksys 3102 works fine and the voice is quite clear
