Which IP to use in 'Contact' field for registration:
Discussion in '3CX Phone System - General' started by SIPfun, Jul 1, 2008.
  1. SIPfun
    Jun 23, 2008
    56
    In the LINES setup, I have (3) choices;
    External (STUN resolved)
    Internal
    or Specified.
    My internal & external IPs are static for my PBX... Is it better to just use my external (or internal) since they will always be the same IP, and never need to be resolved? And does specified refer to the internal, or external (if at all)?
