Which is the most 3cx compatible Gateway.
Discussion in '3CX Phone System - General' started by MB1, Nov 9, 2011.
  1. MB1
    MB1
    Nov 2, 2007
    39
    Hi all,
    I have been struggling to configure my MP114 2FXO 2FXS gateway, and I finally give up!
    I would greatly appreciate advice as to which gateway is the most compatible with 3cx (2FXO 2FXS).
    Regards,
    MB1
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    I would recommend 2 pcs. of Cisco/Linksys SPA-3102.
    I have never experienced any problem (more than 500 pcs. installed, not only with 3CX).
    Regards
  3. netswork
    netswork Active Member
    Mar 11, 2011
    577
    The patton devices are solid.
  4. eagle2
    Apr 27, 2011
    1,085
    11
    OK,
    I generally agree about Patton -- I can't complain about stability, but are much more difficult to setup plus they are at least twice more expensive.
    Regards
  5. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Pattons are dead simple to configure, takes me generally about a minute. 3CX generates the config file, upload the file to the Patton, hit reload. Very simple.
  6. netswork
    Mar 11, 2011
    577
    When I first started using 3cx I was hesitant to use the patton. I have since installed 2 PRI's using pattons and it is so easy, and it just works. If I was to do the same operation with a cisco router on a UC system it would take a lot more time. Been very impressed, but they are expensive.
  7. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    There is only one problem. You need to choose the device which is compatible with your PSTN line.
  8. tsteffens
    Jul 14, 2011
    85
    Patton support is the best IMO.
  9. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Depends on your line and use. Grandstream works well on most lines IF you can configure it properly. Patton is generally easier but more $$$
  10. MB1
    MB1
    Nov 2, 2007
    39
    Thanks everyone.
    Bizarrely I have just finally managed to configure my MP114.
    I only wish that I had bought a different gateway in the first place......
