- Joined
- Oct 7, 2008
- Messages
- 20
- Reaction score
- 0
I'm using 3cx v7 8user edition with cisco 7960 handsets
Everything is working fine so far
Problem I got is how to change the order to display Group ID first then CLI on the phone's display
When I tick "Display group ID" in advanced tab it adds Group ID to the call info however
it is displayed on my CISCO in following order:
CLI space GROUP ID
So when I got incoming call I can see clearly caller ID eg 0201234123 then Group ID
however I can not see whole Group ID name as Cisco display is limited in length
so what I actualy see is only first 3 letters of Group ID
Question are:
Does any one know if its possible to change the order to display Group ID then CLI on Cisco 7960 and how?
If not which phones have ability to change the order on their display or simply display Group ID then CLI as default?
(I think either Astra or Snom display Group ID then CLI)
Which phone in your opinion is most flexible with regards to program its display, buttons etc
Cheers
Shaun
CLI space GROUP ID
Question are:
Cheers
Shaun
