Which ports of firewall should turn on for 3cx ??
Discussion in '3CX Phone System - General' started by kate, Jan 31, 2008.
  1. kate
    Jan 14, 2008
    18
    Hi all ~~
    Does external extension must set " stun " ??
    thx~
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    Read the technical Manual or search on: port forwarding
  3. kate
    Jan 14, 2008
    18
    hi all~
    I can't register form the external phone , I wonder that problem is firewall .
    Could anyone tell me which port I have to turn on , Thx
  4. landfiets
    Jul 17, 2007
    243
    5060 and depending on your phone maybe an other port
    Read the manual of this phonesystem and your phone.
