Which PSTN Adapter for 3cx voip?
Discussion in '3CX Phone System - General' started by Tommas, Oct 14, 2010.
  1. Tommas
    Oct 14, 2010
    Hi!
    Please suggest me supported PSTN adapter for 3cx. We would like to make voip system.
    THX,
    Tommas
    11,291
    361
    You are looking for a Gateway then, a "box" to connect 3CX to telephone lines from your local provider? If so, you have two ways to go, it all depends on how many lines you need now and plan on using in the future. There are single line units, which while less expensive, will add up it you will eventually need four or more lines. There are other devices that handle four, eight or more lines. Many have been discussed on the forums. Certain units are favoured by some users as being reliable and easy to set up. Other users will base the purchase on price, willing to trade off some features and ease for a more economical device.
    If you narrow down what you feel will best serve your initial and future needs, people on the forum might be able to come up with some choices for you.
  3. danoh
    Aug 18, 2010
    56
    I've had good luck with Grandstream GXW-4104 and 4108 units.
  4. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Grandstream and Patton, the second is better but more expensive.
