which should I choose for 3CX v7 , IIS or bundled webserver
Discussion in '3CX Phone System - General' started by deer307, Dec 23, 2008.
  1. deer307
    Nov 11, 2008
    when I install the 3CX V7 , which should I choose for 3CX v7 , IIS or bundled webserver
    thx
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    We recommend that you use IIS.
  3. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    When I installed Version 7 It did not recognize my IIS on XP Pro. So I just went with the bundle.
    I have less than 10 ext. so performance is not a issue.
