Which Wireless phone are supported in 3CX PBX
Discussion in '3CX Phone System - General' started by Daniel Sobrinho, Jan 14, 2019.
  1. Daniel Sobrinho
    Aug 13, 2018
    10
    Hi team,
    Which wireless phone are supported in 3cx pbx?
    I have found the snom M3 wireless phone. Is there more vendors supported? like WP820 from grandstream etc.
    #1 Daniel Sobrinho, Jan 14, 2019
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,327
    221
    No wireless phones, just dect phones.
    Here is the list of phones https://www.3cx.com/sip-phones/
    You may find users using other phones without any issues, but they will not bensupported
  3. Daniel Sobrinho
    Aug 13, 2018
    10
    Hi Saqqara,
    Thank you for answer but I have already this link and there is no reference for wireless SIP phones. only Dect phones (cordless).
  4. 3cxnub
    Nov 1, 2014
    53
    6
    i use the panasoic kx-tap65, its tricky to get call parking working but it works ok.
  5. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,773
    278
    Then you have your answer. That page is the official list of all supported phones.
  6. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    51
    @Daniel Sobrinho
    The Snom M3 wireless phone is a wireless DECT phone. It's very old and EOL, but work with the 3CX PBX because the used SIP standard. You can just make and receive call nothing more, nothing less. No CTI, no certificate, Incompatible with secure "SSL Transport and Ciphers" setting, completely unsupported device.
    Provisioning/setup of the base has to make manually.
  7. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,609
    209
  8. Daniel Sobrinho
    Aug 13, 2018
    10
    Thank you guys for ALL answers. I am very appreciate.
  9. Lee Cramman
    Lee Cramman New Member
    Jul 9, 2018
    182
    21
    There has definitely been a decline in traditional wireless phones and a push to use app based soft phones running on Android / iOS.
    Might be time to look at that as an alternative.
  10. eddv123
    Aug 15, 2017
    1,609
    209
