White List vs Black List
Discussion in '3CX Phone System - General' started by Bob Denny, Apr 6, 2018.
  1. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    Our switch is publicly visible as we call in from the road via 4G/5G mobile data (Bria SIP phones), public WiFI (yes we know the risks) etc. Meanwhile the switch busters are constantly trying to break in, resulting in a steady stream of auth and request caused blacklisting. I looked in the manual but it is unclear how the white list vs black list rules are applied. Suppose I blocked everything 0.0.0.0/0.0.0.0 with a blacklist entry, then I add white list entries for our office net and Verizon mobile data. Before I waste my time and cause problems here in the office, can someone explain how the rules are applied. Do white lists override black lists or ???
    11,263
    359
    I'm not certain that doing blanket blacklist on 3CX is the best option, or that the whitelist will override (never tried it). Generally blocking everything, BUT... is best done on a router or firewall.
  3. Bob Denny
    Feb 21, 2009
    131
    I would except the phone switch is running on Google Cloud. I have no control over any firewall etc.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,749
    560
  5. Bob Denny
    Feb 21, 2009
    131
  6. StefanW
    Jun 2, 2009
    1,229
    95
    yes, but in your setup do not use 3CX to do this job of filtering. It will consume to much power.
    Use the default OS firewalls (Windows Firewall or Linux IPtables) to do the job.
    To your question, white list is over blacklist.
    If set
    Block: 0.0.0.0/0
    White: 1.2.3.4/32
    Only 1.2.3.4/32 will be allowed.
  7. dredd0606
    Feb 14, 2018
    43
    15
    If you are running on Google Cloud, they have very robust firewall tools that you can customize to your hearts content, using the link you provided. They do not run on the VM, but rather as part of your virtual network. I greatly prefer offloading the firewall to google than using iptables on the pbx.
  8. Bob Denny
    Feb 21, 2009
    131
    Ah! I will look. I have been ultra busy. Right now I only have 28 blacklists.
