21-Nov-2012 16:11:52.861 L:996.1[Line:10012<<2047297860]: Terminating targets, reason:
21-Nov-2012 16:11:52.861 Leg L:996.1[Line:10012<<2047297860] is terminated: Cause: BYE from PBX
21-Nov-2012 16:11:52.861 L:996.1[Line:10012<<2047297860] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=c165ba5f0d31957c Call-ID=9454bda87c2f76e5:
BYE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-c165ba5f0d31957c-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]:5060>;tag=61287c5f20
From: "Brooke Ward"<sip:[email protected]:5060>;tag=16775139
Call-ID: 9454bda87c2f76e5
CSeq: 3 BYE
Content-Length: 0
21-Nov-2012 16:11:52.861 [CM503008]: Call(C:996): Call is terminated
21-Nov-2012 16:11:52.861 L:996.1[Line:10012<<2047297860]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
21-Nov-2012 16:11:52.860 Blocking refers for the Call(C:996)
21-Nov-2012 16:11:52.860 Call(C:996) is terminated
21-Nov-2012 16:11:52.859 L:996.3[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
21-Nov-2012 16:11:52.859 Leg L:996.3[Extn] is terminated: Cause: BYE from 192.168.16.61:5060
21-Nov-2012 16:11:52.857 L:996.3[Extn] got Terminated Recv Req BYE from 192.168.16.61:5060 tid=579229764 Call-ID=OWE1MGVhYTEwNDgwYjRmNTU3YjkwZWIzOGUxY2I3YjM.:
Via: SIP/2.0/UDP 192.168.16.61:5060;branch=z9hG4bK579229764;rport=5060
Max-Forwards: 70
Contact: <sip:[email protected]:5060;user=phone>
To: <sip:[email protected]:5060;nf=e>;tag=272d121f
From: <sip:[email protected]>;tag=467982843;intercom=true
Call-ID: OWE1MGVhYTEwNDgwYjRmNTU3YjkwZWIzOGUxY2I3YjM.
CSeq: 2 BYE
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
Supported: replaces, path, timer
User-Agent: Grandstream GXP1450 1.0.4.23
Content-Length: 0
21-Nov-2012 16:11:52.857 L:996.3[Extn] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=579229764 Call-ID=OWE1MGVhYTEwNDgwYjRmNTU3YjkwZWIzOGUxY2I3YjM.:
SIP/2.0 200 OK
CSeq: 2 BYE
Content-Length: 0
21-Nov-2012 16:11:49.219 L:996.3[Extn] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=066ac00f026dd30a Call-ID=OWE1MGVhYTEwNDgwYjRmNTU3YjkwZWIzOGUxY2I3YjM.:
ACK sip:[email protected]:5060;user=phone SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-066ac00f026dd30a-1---d8754z-;rport
Max-Forwards: 70
To: <sip:[email protected]>;tag=467982843;intercom=true
From: <sip:[email protected]:5060;nf=e>;tag=272d121f
CSeq: 1 ACK
Content-Type: application/sdp
Content-Length: 299
v=0
o=3cxPS 191679692800 147085852673 IN IP4 192.168.16.100
s=3cxPS Audio call
c=IN IP4 192.168.16.101
t=0 0
m=audio 5132 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
21-Nov-2012 16:11:49.217 Reneg. from L:996.1[Line:10012<<2047297860], answer
21-Nov-2012 16:11:49.217 Leg L:996.1[Line:10012<<2047297860] raised event RecvdRemoteSdp
21-Nov-2012 16:11:49.217 Remote SDP is set for leg L:996.1[Line:10012<<2047297860]
21-Nov-2012 16:11:49.217 NAT/ALG check:L:996.1[Line:10012<<2047297860] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
21-Nov-2012 16:11:49.216 Answer SDP arrived on Leg L:996.1[Line:10012<<2047297860];
OnAnswer Recv 200/INVITE from 192.168.16.101:5060 tid=897a7c6761462948 Call-ID=9454bda87c2f76e5:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.16.100:5060;branch=z9hG4bK-d8754z-897a7c6761462948-1---d8754z-;rport=5060;received=192.168.16.100
CSeq: 2 INVITE
Server: Patton SN4114 JO EUI 00A0BA07922A R6.2 2012-09-11 H323 SIP FXS FXO M5T SIP Stack/4.0.30.30
Supported: replaces
Content-Length: 271
v=0
o=MxSIP 0 624 IN IP4 192.168.16.101
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
21-Nov-2012 16:11:49.216 L:996.1[Line:10012<<2047297860] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=be6cec77e420b919 Call-ID=9454bda87c2f76e5:
ACK sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-be6cec77e420b919-1---d8754z-;rport
Max-Forwards: 70
CSeq: 2 ACK
Content-Length: 0
21-Nov-2012 16:11:49.197 L:996.2[Queue]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
21-Nov-2012 16:11:49.197 Leg L:996.2[Queue] is terminated: Cause: BYE from 127.0.0.1:5488
21-Nov-2012 16:11:49.195 L:996.2[Queue] got Terminated Recv Req BYE from 127.0.0.1:5488 tid=e9278b538a5a9c79 Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-d8754z-e9278b538a5a9c79-1---d8754z-;rport=5488
Max-Forwards: 70
Contact: <sip:[email protected]:5488>
To: <sip:[email protected]:5060;nf=e>;tag=600f296d
Call-ID: ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.
CSeq: 5 BYE
User-Agent: 3CX Queue Manager (q=500)
Reason: SIP;description="User Hung Up"
Content-Length: 0
21-Nov-2012 16:11:49.195 L:996.2[Queue] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=e9278b538a5a9c79 Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
SIP/2.0 200 OK
CSeq: 5 BYE
Content-Length: 0
21-Nov-2012 16:11:49.057 [CM503007]: Call(C:996): Extn:222 has joined, contact <sip:[email protected]:5060>
21-Nov-2012 16:11:49.056 L:996.1[Line:10012<<2047297860] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=642e891f91624d01 Call-ID=9454bda87c2f76e5:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-642e891f91624d01-1---d8754z-;rport
Max-Forwards: 70
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Supported: replaces
Content-Length: 429
v=0
o=3cxPS 118346481664 12113149954 IN IP4 192.168.16.100
s=3cxPS Audio call
c=IN IP4 192.168.16.61
t=0 0
m=audio 5004 RTP/AVP 0 8 9 18 97 2 4 101
a=ptime:20
a=rtpmap:9 G722/8000
a=fmtp:18 annexb=no
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=rtpmap:2 G726-32/8000
a=rtpmap:4 G723/8000
a=fmtp:101 0-15
a=sendrecv
21-Nov-2012 16:11:49.053 L:996.1[Line:10012<<2047297860]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
21-Nov-2012 16:11:49.052 L:996.3[Extn] has joined to L:996.1[Line:10012<<2047297860]
21-Nov-2012 16:11:49.052 Session 170987 of leg L:996.3[Extn] is connected
21-Nov-2012 16:11:49.052 L:996.3[Extn] got Connected.UAC Recv 200/INVITE from 192.168.16.61:5060 tid=b83a0b72840f9511 Call-ID=OWE1MGVhYTEwNDgwYjRmNTU3YjkwZWIzOGUxY2I3YjM.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.16.100:5060;branch=z9hG4bK-d8754z-b83a0b72840f9511-1---d8754z-;rport=5060
CSeq: 1 INVITE
Content-Length: 403
v=0
o=222 8000 8000 IN IP4 192.168.16.61
s=SIP Call
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:97 mode=30
a=fmtp:101 0-15
21-Nov-2012 16:11:49.052 Remote SDP is set for leg L:996.3[Extn]
21-Nov-2012 16:11:49.052 NAT/ALG check:L:996.3[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
21-Nov-2012 16:11:49.052 Offer SDP arrived on Leg L:996.3[Extn];
OnOffer Recv 200/INVITE from 192.168.16.61:5060 tid=b83a0b72840f9511 Call-ID=OWE1MGVhYTEwNDgwYjRmNTU3YjkwZWIzOGUxY2I3YjM.:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 403
v=0
s=SIP Call
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:97 mode=30
a=fmtp:101 0-15
21-Nov-2012 16:11:49.052 [CM503002]: Call(C:996): Alerting Extn:222 by contact <sip:[email protected]:5060>
21-Nov-2012 16:11:49.050 UacSession 170987 has formed leg L:996.3[Extn]
21-Nov-2012 16:11:48.236 [CM503025]: Call(C:996): Calling T:Extn:222@[Dev:sip:[email protected]:5060;user=phone] for L:996.1[Line:10012<<2047297860]
21-Nov-2012 16:11:48.236 Route to L:996.3[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=cf3aa735277b4d2c Call-ID=OWE1MGVhYTEwNDgwYjRmNTU3YjkwZWIzOGUxY2I3YjM.:
INVITE sip:[email protected]:5060;user=phone;intercom=true SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-cf3aa735277b4d2c-1---d8754z-;rport
Max-Forwards: 70
To: <sip:[email protected]>;intercom=true
CSeq: 1 INVITE
Alert-Info: <http://www.notused.invalidtld>;info=external
Call-Info: <sip:3cx.pbx>;answer-after=0
Supported: replaces
Referred-By: <sip:[email protected]>
Replaces: ZGMwNDU1ZjdkZmVhZGVmMWIxZTlmOTkyYmYwMWM1MTA.;to-tag=1459151241;from-tag=3913736b
Content-Length: 0
21-Nov-2012 16:11:48.229 Added leg L:996.3[Extn]
21-Nov-2012 16:11:48.179 Call(C:996): Refer is using Replaces
21-Nov-2012 16:11:48.179 L:996.1[Line:10012<<2047297860]: Updated OutCID: '10012' and DNName: ''
21-Nov-2012 16:11:48.179 Call(C:996): Referred(i): src=<sip:[email protected]:5060;nf=e>; dst=<sip:[email protected]:5060>
21-Nov-2012 16:11:48.179 Call(C:996): Replaces: L:1001.3[Extn]
21-Nov-2012 16:11:48.179 Call transfer requested on Leg L:996.2[Queue];
Refer Recv Req REFER from 127.0.0.1:5488 tid=9f1c19689a3c5e6f Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
REFER sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-d8754z-9f1c19689a3c5e6f-1---d8754z-;rport=5488
Max-Forwards: 70
CSeq: 3 REFER
Refer-To: <sip:[email protected]:5060;nofwd=1;tag3cx=28-MGDSLWTTMM?Replaces=MjIwMmFlY2Q2YTgwZDZiMWFjZWZiNmI5ZTJhNTNiYjQ.%3Bto-tag%3D2573db51%3Bfrom-tag%3Da4620c76>;tag=2573db51
Content-Length: 0
21-Nov-2012 16:11:08.196 L:996.2[Queue] got INFO SipInfo Recv Req INFO from 127.0.0.1:5488 tid=97642b3aa048cf58 Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
INFO sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-d8754z-97642b3aa048cf58-1---d8754z-;rport=5488
Max-Forwards: 70
CSeq: 2 INFO
Content-Type: application/component-call-info
Content-Length: 22
qcid=23-XNPHTOJCDE
21-Nov-2012 16:11:08.196 L:996.2[Queue] Sending: OnSendResp Send 200/INFO from 0.0.0.0:0 tid=97642b3aa048cf58 Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
SIP/2.0 200 OK
CSeq: 2 INFO
Content-Length: 0
21-Nov-2012 16:11:08.083 Session 170909 of leg L:996.1[Line:10012<<2047297860] is confirmed
21-Nov-2012 16:11:08.083 L:996.1[Line:10012<<2047297860] got Confirmed Recv Req ACK from 192.168.16.101:5060 tid=e3d5e340d30e31a12 Call-ID=9454bda87c2f76e5:
Via: SIP/2.0/UDP 192.168.16.101:5060;branch=z9hG4bKe3d5e340d30e31a12
Max-Forwards: 70
To: <sip:[email protected]:5060>;tag=16775139
CSeq: 17266 ACK
Proxy-Authorization: Digest username="10012",realm="3CXPhoneSystem",nonce="414d535c06bde27b14:6553839a0d3dfd96ad381c3fd062d1d0",uri="sip:[email protected]:5060",response="cddeaf80ab0aa3c8083fe4bd8d5caa77",algorithm=MD5
User-Agent: Patton SN4114 JO EUI 00A0BA07922A R6.2 2012-09-11 H323 SIP FXS FXO M5T SIP Stack/4.0.30.30
Content-Length: 0
21-Nov-2012 16:11:07.892 [CM503007]: Call(C:996): Queue:500 has joined, contact <sip:[email protected]:5488>
21-Nov-2012 16:11:07.891 [CM503007]: Call(C:996): Line:10012<<2047297860 has joined, contact <sip:[email protected]:5060>
21-Nov-2012 16:11:07.891 Session 170909 of leg L:996.1[Line:10012<<2047297860] is connected
21-Nov-2012 16:11:07.891 L:996.1[Line:10012<<2047297860] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=387b2c4269af364ed Call-ID=9454bda87c2f76e5:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.16.101:5060;branch=z9hG4bK387b2c4269af364ed
CSeq: 17266 INVITE
Supported: replaces
User-Agent: 3CXPhoneSystem 11.0.27588.780 (27565)
Content-Length: 239
v=0
o=3cxPS 118346481664 12113149953 IN IP4 192.168.16.100
s=3cxPS Audio call
c=IN IP4 192.168.16.100
t=0 0
m=audio 7062 RTP/AVP 8 0 101
a=fmtp:101 0-16
21-Nov-2012 16:11:07.891 L:996.1[Line:10012<<2047297860] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=387b2c4269af364ed Call-ID=9454bda87c2f76e5:
SIP/2.0 200 OK
CSeq: 17266 INVITE
Supported: replaces
Content-Length: 239
v=0
s=3cxPS Audio call
t=0 0
a=fmtp:101 0-16
21-Nov-2012 16:11:07.888 L:996.1[Line:10012<<2047297860]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
21-Nov-2012 16:11:07.888 L:996.2[Queue] has joined to L:996.1[Line:10012<<2047297860]
21-Nov-2012 16:11:07.888 Session 170912 of leg L:996.2[Queue] is connected
21-Nov-2012 16:11:07.888 L:996.2[Queue] got Connected.UAC Recv 200/INVITE from 127.0.0.1:5488 tid=f635a81fb8618c78 Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-d8754z-f635a81fb8618c78-1---d8754z-;rport=5060
To: <sip:[email protected]>;tag=3e23f445
From: <sip:[email protected]:5060;nf=e>;tag=600f296d
CSeq: 1 INVITE
Supported: replaces
Content-Length: 226
v=0
o=3cxVCE 62947155 286675590 IN IP4 127.0.0.1
s=3cxVCE Audio Call
c=IN IP4 127.0.0.1
t=0 0
m=audio 32044 RTP/AVP 8 0 101
a=fmtp:101 0-16
21-Nov-2012 16:11:07.887 Remote SDP is set for leg L:996.2[Queue]
21-Nov-2012 16:11:07.887 NAT/ALG check:L:996.2[Queue] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
21-Nov-2012 16:11:07.887 Answer SDP arrived on Leg L:996.2[Queue];
OnAnswer Recv 200/INVITE from 127.0.0.1:5488 tid=f635a81fb8618c78 Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 226
v=0
s=3cxVCE Audio Call
c=IN IP4 127.0.0.1
t=0 0
a=fmtp:101 0-16
21-Nov-2012 16:11:07.887 L:996.2[Queue] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=413b802f2322a81c Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
ACK sip:[email protected]:5488 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-413b802f2322a81c-1---d8754z-;rport
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
21-Nov-2012 16:11:07.886 L:996.1[Line:10012<<2047297860] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=387b2c4269af364ed Call-ID=9454bda87c2f76e5:
SIP/2.0 180 Ringing
CSeq: 17266 INVITE
Content-Length: 0
21-Nov-2012 16:11:07.886 Provisional response arrived for session 170912 of Leg L:996.2[Queue]
21-Nov-2012 16:11:07.886 L:996.2[Queue] got Provisional Recv 180/INVITE from 127.0.0.1:5488 tid=f635a81fb8618c78 Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Content-Length: 0
21-Nov-2012 16:11:07.886 [CM503002]: Call(C:996): Alerting Queue:500 by contact <sip:[email protected]:5488>
21-Nov-2012 16:11:07.884 UacSession 170912 has formed leg L:996.2[Queue]
21-Nov-2012 16:11:07.756 [CM503025]: Call(C:996): Calling T:Queue:500@[Dev:sip:[email protected]:5488] for L:996.1[Line:10012<<2047297860]
21-Nov-2012 16:11:07.756 Route to L:996.2[Queue] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=6d7ae15f763f857c Call-ID=ZDQ4NTgyMDc2N2QzYjgwNTY4M2RlZjY5MDA5OTQ0Zjc.:
INVITE sip:[email protected]:5488 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-6d7ae15f763f857c-1---d8754z-;rport
Max-Forwards: 70
CSeq: 1 INVITE
Supported: replaces
Content-Length: 289
v=0
o=3cxPS 347439366144 354636791809 IN IP4 127.0.0.1
s=3cxPS Audio call
c=IN IP4 127.0.0.1
t=0 0
m=audio 7064 RTP/AVP 8 0 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=sendrecv
21-Nov-2012 16:11:07.748 Added leg L:996.2[Queue]
21-Nov-2012 16:11:07.715 [Flow] Call(C:996): making call from L:996.1[Line:10012<<2047297860] to T:Queue:500@[Dev:sip:[email protected]:5488]
21-Nov-2012 16:11:07.715 [CM503005]: Call(C:996): Forwarding: T:Queue:500@[Dev:sip:[email protected]:5488]
21-Nov-2012 16:11:07.714 [Flow] L:996.1[Line:10012<<2047297860]: Build targets for Queue:500
21-Nov-2012 16:11:07.714 L:996.1[Line:10012<<2047297860] forwards call from Extn:401 to Queue:500 based on rule Fwd[Available/NotReg]
21-Nov-2012 16:11:07.714 L:996.1[Line:10012<<2047297860] failed to reach Extn:401, reason Not Registered
21-Nov-2012 16:11:07.714 Leg L:996.1[Line:10012<<2047297860]: Refreshing OutCID from endpoint Extn:401 = []
21-Nov-2012 16:11:07.714 [CM503016]: Call(C:996): Attempt to reach <sip:[email protected]:5060> from Line:10012<<2047297860 has failed. Reason: Not Registered
21-Nov-2012 16:11:07.714 [CM503017]: Call(C:996): Target is not registered: Extn:401
21-Nov-2012 16:11:07.713 [Flow] Call(C:996): has built target endpoint: Extn:401 for call from L:996.1[Line:10012<<2047297860]
21-Nov-2012 16:11:07.713 [CM503010]: Call(C:996): Making route(s) from Line:10012<<2047297860 to <sip:[email protected]:5060>
21-Nov-2012 16:11:07.713 Remote SDP is set for leg L:996.1[Line:10012<<2047297860]
21-Nov-2012 16:11:07.711 [CM500002]: Call(C:996): Info on incoming INVITE from Line:10012<<2047297860:
Invite-IN Recv Req INVITE from 192.168.16.101:5060 tid=387b2c4269af364ed Call-ID=9454bda87c2f76e5:
Max-Forwards: 70
CSeq: 17266 INVITE
Supported: replaces
Content-Length: 271
v=0
o=MxSIP 0 619 IN IP4 192.168.16.101
s=SIP Call
t=0 0
m=audio 5132 RTP/AVP 8 0 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=sendrecv
