Why doesn't the 3CX mobile client push GSM presence to 3CX????
Discussion in 'Android' started by Sorby, Feb 6, 2018.
  1. Sorby
    Jan 27, 2017
    18
    12
    Isn't there no one else then us who is annoyed that colleagues and the switchboard transfer calls to you when you're busy in a mobile phone call?
    jed, bodleid and andrewmbioquell like this.
  2. bodleid
    Jan 19, 2010
    5
    6
    Agree, this is must in Nordic countries, you need to have api for busy in mobile or similar solution you describe above. It is really hard to sell 3CX system in Nordic without this feature since this is requirement with almost all companies
    jed likes this.
  3. leejor
    10,368
    228
    I wasn't aware that PUSH itself was a bi-directional feature, or even capable of doing that.
    It would probably have to happen where when a PUSH message was sent to the phone, the phone wakes up and 3CX registers, at the same time, the state of the phone would be noted. If engaged, then that fact would have to be passed back to the PBX during, or just after, registration so that the call could be handled as if the extension were engaged.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    there is a new beta version currently under testing that addresses this issue. You could download that and let us know if that helps. There is an option included in the client you can toggle on and off to have the client ignore sip calls while you are on a GSM call. The option is under advanced settings
  5. Sorby
    Jan 27, 2017
    18
    12
    This does not solve the issue, the switchboard and other extension still "see" the extension they transfers the call to as "available" when they actually are in a active GSM call.
    The "Busy When On GSM Call" feature in the beta app dosen`t change the presence color in 3CX.
    jed likes this.
  6. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,442
    61
    Hi @Sorby @bodleid
    Basically, what you ask for is 3CX client to act as a service continuously monitoring the GSM calls and notifying/updating accordingly MyPhone's status. Am I correct?
    jed likes this.
  7. Sorby
    Jan 27, 2017
    18
    12
    Yupp! Thats correct :) Just like Innovaphones myPBX apps and others does...
    jed likes this.
  8. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    I think there is again confusion here. This is not related to FCM which never throttles messages with a time-to-live value of 0 seconds.
    I think that OP would like to see PhoneStateListener which 3CXPhone should use to notify PBX about change.
    #8 Sopock, Feb 16, 2018
  9. Vali_3CX
    Dec 12, 2008
    1,442
    61
    @Sorby
    Sorry to dissapoint you, but I don't see that feature implemented too soon, and that's because we tried it already and it was available for few months then we removed it; the main reason: sometimes those extensions remained stuck in "DND-In GSM call" indefinitely, because the GSM call lasted longer than 3CX client' maximum allowed background time, so the OS was killing the client. With its status remaining in DND, even in today's PUSH environment, no incoming call would be allowed by the PBX to wake app up back.
    As I mentioned - this was the main reason. Add to this that an application running in the backround 24 hours per day 7 days per week it's a hell of resources consumer. There were also reasons related to network rights, PBX restarting, user deleting/switching account, etc, which, bottom line, made this concept very unreliable.
    I'm assuming that, despite my explanation, you're still keen to see it implemented - in this case, my advice is to post it to the Ideas section (as far as I remember, there is already there posted by somebody before you quite long time ago).
    Regards
    vali
    LATER EDIT:
    Oh, it was you then too, 2017 :D
    https://www.3cx.com/community/threads/mobile-phone-availability-connector-to-3cx.49010/
    #9 Vali_3CX, Feb 16, 2018
  10. agentsmithitaly
    Jan 3, 2018
    27
    @Vali_3CX you could implement this as a client-server service, where the the client continuously update the server like once every 30 seconds, if client is in background is killed by OS, the server will automatically restore the presence as Available after some minutes of missing updates.
    The very same technique could be used to avoid "stuck calls" due to internet connection dropped while on a phone call. What do you think?
  11. Sorby
    Jan 27, 2017
    18
    12
    I think this is a good idea!
    Much better then no "in active call" presence at all when in a GSM call.
    You have my vote :)
