I apply all of equipments: PAP2T, SPA941 and SPA3102(line) the symptoms are same.
A failed call with rule "1":
15:51:05.708 CallConf:
nIncoming [CM003002] Call(54): Destination not available for call from sip:
[email protected] to sip:
[email protected]
15:51:05.708 CallConf::Rejected [CM103005] Call(54) is rejected: Destination does not exist, or is not registered
15:51:05.224 CallConf:
nIncoming [CM103002] Call(54): Incoming call from 216 (Ext.216) to sip:
[email protected]
A successful call with rule "4":
16:02:09.265 StratLink:
nHangUp [CM104001] Call(56): Ext.216 hung up call; cause: BYE; from IP:10.0.0.5
16:01:51.922 CallLegImpl:
nConnected [CM103001] Call(56): Created audio channel for Ln:30000@tda110 (10.0.0.2:16464) with third party (10.0.0.5:16406)
16:01:51.906 StratInOut:
nConnected [CM104005] Call(56): Setup completed for call from Ext.216 to Ln:30000@tda110
16:01:51.906 CallLegImpl:
nConnected [CM103001] Call(56): Created audio channel for Ext.216 (10.0.0.5:16406) with third party (10.0.0.2:16464)
16:01:51.890 CallConf:
nProvisional [CM103003] Call(56): Ln:30000@tda110 is ringing
16:01:51.609 CallConf:
nIncoming [CM103002] Call(56): Incoming call from 216 (Ext.216) to sip:
[email protected]
Ext216 is an SPA941
