WHY it is no work corectly???
Discussion in '3CX Phone System - General' started by paul-cdma, Jun 29, 2007.
  1. paul-cdma
    Jun 29, 2007
    20
    17:52:23.359 StratInOut::eek:nHangUp [CM104007] Call(58): Call from Ln:10001@dlink 6004s to 999 has been terminated by Ln:10001@dlink 6004s; cause: BYE; from IP:217.30.245.110
    17:52:19.421 CallLegImpl::eek:nConnected [CM103001] Call(58): Created audio channel for Ln:10001@dlink 6004s (217.30.245.110:9002) with Media Server (217.30.245.111:7116)
    17:52:16.781 CallConf::eek:nProvisional [CM103003] Call(58): Ext.500 is ringing
    17:52:16.546 CallConf::eek:nIncoming [CM103002] Call(58): Incoming call from 10001 (Ln:10001@dlink 6004s) to sip:8432505999@217.30.245.111
    I use dlink fxo gateway and call for 8432505999. why 3cx divert call for ext500?
  2. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    you should provide more information, but you can try the following:
    check your dial rules. the r in the transform mask removes the first digit dialed.
    also check the gateway configuration if its registered properly and the phone too.
  3. paul-cdma
    Jun 29, 2007
    20
    rule is three for digit 0 - to dlink gateway, for digit 2 and 3 into same dlink. dllink is registered properly, I can call to line connected to dlink interface correctly, but if i call to line into dlink and it`s trans my call and dialed number into 3cx ( 8432505999...) and why it transfer this call into 500?
  4. paul-cdma
    Jun 29, 2007
    20
    [CM104007] Call(2): Call from Ln:10001@dlink 6004s to 500 has been terminated by Ln:10001@dlink 6004s; cause: CANCEL; from IP:217.30.245.110
    18:15:55.203 CallConf::eek:nProvisional [CM103003] Call(2): Ext.500 is ringing
    18:15:54.968 CallConf::eek:nIncoming [CM103002] Call(2): Incoming call from 10001 (Ln:10001@dlink 6004s) to sip:2505999@217.30.245.111
    why? it is dont see number 2505999 and transfer call to ext 500
  5. paul-cdma
    Jun 29, 2007
    20
    the route conf for internal call for this device is route for exten 500... but why it`s dont analizy number what i deal in
  6. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    what does you outbound rule say? you still have the default rule in there?
    If so, remove the "r" in the transform mask. hope it helps
  7. paul-cdma
    Jun 29, 2007
    20
  8. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    checking just a sec
  9. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    I think you have to play with the gateway is external settings for a bit.
    But to get it straight:
    Outgoing calls work?
    Incomming calls work?
    Incomming calls display wrong number?
    Or number you dial out gets transformed?
  10. paul-cdma
    Jun 29, 2007
    20
    no! I can call from ext 500 ( softphone) to any ( this is corect) but if i call for line into dlink and it transf this call to 3cx... any dealed number was transfered to ext 500. fo example i call to fxo line ( like pstn call) hear voice promt to deal number... then dial 2505999. dlink place sip call to 3cx and 3cx was transfer this call for ext.500 in anytime or any dealed number
  11. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    Changed above msg, please check again :D
    All looks ok on your server tho. But maybe i have to make an extension for myself and see what happens?
    What country are you in?
  12. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    also you can play around with editing the "other settings" of the voip gateway, specially the
    caller id
    called number settings.
  13. paul-cdma
    Jun 29, 2007
    20
    I am from russia please you can do ext for yourself and try
  14. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    also play around with extension is external setting in the extension settings, provide the softphone also with a stun-server adress to take away any NAT related problems.
  15. paul-cdma
    Jun 29, 2007
    20
    there is no NAT problem be cause i use only ext ip adress
  16. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    ok created an extension, gotta eat now be back in 30 mins ill look into it some more.
  17. paul-cdma
    Jun 29, 2007
    20
    OK i find a solution. the problem is in default gateway and dialed number plan in 3cx. Thank`you All :D
  18. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    no problem mate glad you got it solved
