Why large delay takes place if using "Transcoding mode"?
Discussion in '3CX Phone System - General' started by Alexord, Jul 11, 2008.
  1. Alexord
    May 28, 2008
    19
    I have 3cx installed on separate server, I can see that neither CPU nor memory usage is high but I still have delay in conversation independently of codec. Does it point to network problem or something wrong with my server? Any ideas?
    In proxy mode I still have delay but less noticeable (100-150 ms in proxy mode contra 500 - 700 ms in Transcoding mode). All SIP test shows good results - approximately 65 ms delay in trace route and 0% packet loss.
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    What type of delay are you talking about for example is it:
    h--e--l--l--o--
    or is it
    hello-----how----are----your
    Please advise.
    H.
  3. francesco
    francesco New Member
    Jun 23, 2008
    102
    which are the characteristics of the system that you use?
  4. Alexord
    May 28, 2008
    19
    If I call myself on cell phone and say hello, I'll hear this "hello" on other phone after some time. But quality of sound is good.
    I use Pentium 4 - 2400 Mhz, 1 Gb RAM, Windows Server 2003 R2 behind IPtables firewall. This machine running 3CX only.
  5. justin
    Feb 20, 2008
    79
    What sort of delay are we talking about??? 5 secs, 1 sec, .5 sec??? You should expect a short (.5 sec) or so especially on a cell. If it's more it could be bandwidth. Whats your net speed and was anything running in the background that would be consuming your bandwidth?
  6. Alexord
    May 28, 2008
    19
    Yes, I'm talking about delay proximately 0.5 sec.
    This delay appears only in "transconing mode" and even in local calls. If PBX deliver audio is off, there no delay at all in local calls and a little in external. So I don't think that is bandwidth or firewall problem due to same sort of thing in local network...
    What could cause this? Slow machine? If I upgrade it to more faster one, does it helps? There is no anti-virus or any other software except 3CX on this server.
  7. francesco
    Jun 23, 2008
    102
    I don't think that depend on the characteristics of the PC. this is good
  8. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    This delay arises because media server adaptively sets up jitter buffer. If both streams are even and don't deviate from timer - jitter will be less. If streams are not regular (time between packets is not stable) - jitter will increase. Otherwise sound quality will degrade noticeable.
  9. Alexord
    May 28, 2008
    19
    It sounds reasonable, but why its happened even in local network? And also my internet connections tests always show 3-4 ms average jitter...
  10. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    309
    It depends on the quality of the server, internet connection, sip phones, voip provider being used. Lots of variables that come into play here. On the internal network, it should not operate in transcoding mode, not if you are using quality phones and have not changed the settings.
  11. blabla
    Jan 20, 2008
    32
    Is there a possibility to turn off the jitter buffer ?
    I think a "PBX" beeing "in the middle" beteween to partys shouldn't do jitter buffering, unless specificaly ask to do so.
    The best place for jitter buffering is on the devices.
  12. archie
    3CX Support
    Aug 18, 2006
    1,299
    When in proxy mode Media server doesn't add any jitter. In case of transcoding jitter is inevitable.
  13. blabla
    Jan 20, 2008
    32
    Sure, transcoding does add some jitter.
    But I see no good reason to perform full blown jitter buffering except for devices that have have no or no good jitter buffer, or if 3CX itself is the endpoint.
    It just adds delay with no real benefit.
    If packets arrive untimely at 3CX and 3CX is emitting them untimely subsequently the jitter buffer of the endpoint can handle that problem.
  14. archie
    3CX Support
    Aug 18, 2006
    1,299
    As I already told 3CX doesn't have jitter in proxy connections.
    When transcoding - jitter is inevitable, because MS needs some ready protion of decoded data before it can encode them and send out. So, if one endpoint sends 20ms packets, and another endpoint waits for 30ms packets, and second packet arrives in 40ms after first one - what MS should do? Send silence or what?
    Please, let's not discuss technical questions. Believe me, we thought a lot before implement it. If you're good specialist in that area - make a suggestion and we will implement it if find it reasonable. All other talks are in vain, I suppose.
