Why me it doestn't work?
Discussion in '3CX Phone System - General' started by Empi, Feb 10, 2008.
  1. Empi
    Feb 10, 2008
    I do all, for VoIP connection, but it functions only in my computer, if me install 3CX VoIP Client on other PC it doesn't wokr, WHY?
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    did you change the ports to the new one?
  3. matthijsolislagers
    matthijsolislagers New Member
    140
    Do you have a firewall installed on your 3CX server?
  4. Empi
    Feb 10, 2008
    What ports and how?
  5. Empi
    Feb 10, 2008
    Yes, in this isn't problem... thx
  6. landfiets
    landfiets New Member
    Jul 17, 2007
    242
    Hi there. It would be good that you try to explain more about your problem.
    You say not so very much. It could be anything, so please provide us with more details about what happens, what version you use, what ports you opened and forewarded, and what did you fill out in your other computer?
    It is easier for us to answer and reply on your question.
  7. Empi
    Feb 10, 2008
    I'm not from England or USA, but from Czech...
    I'm bad in English, but I attempted
    I do on 3CX 5 and in VoIP client
    I create 3CX system and some users, in my computer is all right, but in other pc NO
    I don't know why, but there's my IP and PORT:
    88.103.15.194:5060
  8. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    You need to have these ports open on your firewall - both on the 3CX PC and if going outside your network also on the router/firewall.
    UDP 5060, 3478, 9000-9015
    You will also need UDP ports 7000-7015 open on the 3CX PC for internal calls.
