why no way to select all in phone firmware update?
Discussion in '3CX Phone System - General' started by asinshesq, Aug 29, 2016.
  1. asinshesq
    Apr 5, 2014
    72
    Just wondering: why isn't there a way to "select all" in phone firmware update downloads, or at least mark the irrelevant phones so they no longer show up? The way it is, you have to either go through all 52 entries one by one or live with the updates button continuing to show 52 updates pending...
  2. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    or even more in some cases :!:
    update-or-download-45286.html
  3. schut
    Jul 30, 2012
    22
    If you hold Ctrl you can select multiple phones and push the firmware update to them all, or well at least you can in v14. If they removed that in v15 would be quite silly...
  4. asinshesq
    Apr 5, 2014
    72
    I never used v 14, but I can say that in v 15 the usual windows trick of holding ctrl down and clicking multiple items does not work (whatever you last clicked is the only thing that remains selected). And the usual windows trick of holding down the shift key and clicking a second item in order to select everything in between doesn't work either.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
