why specify Email from (display name) on every template?
Discussion in 'Ideas' started by the60, Apr 14, 2017.
  1. the60
    the60 New Member
    Oct 21, 2011
    117
    50
    For email templates, we have the option of specifying the "From (Display Name)" on every email template.
    However, it'd be a big time saver if this could be entered only once, and applied to all pertinent email templates, with the option to override a specific template if needed.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    ... thats pretty much what it does now. It'll use the default reply-to in the email settings if you don't put anything in the template section.
  3. the60
    the60 New Member
    Oct 21, 2011
    117
    50
    I know that. Using a "display name" is more professional than an email address.
  4. vizualpro
    Jul 9, 2016
    81
    13
    I agree that there could be a global variable in case you don't want to use reply-to address and also don't want to set them manually. I must say that I do like they can be different though; as someone who gets a lot of email already, being able to search by display name for certain notifications, is really helpful!
