WideBand codec
Discussion in 'Windows' started by istvan, Jul 20, 2008.
  1. istvan
    Jul 19, 2008
    I have just downloaded mizuphone from http: //www.mizutech.hu. It has exceptional sound quality with its speex wideband codec. But when using with 3CX, it always select some lowest qulity codec. Does 3CX support wideband? If yes, how can i force it?
    Thank, istvan
  2. Anonymous
    Anonymous Guest
    Hi there,
    Can you please send us the exact settings used to connect to 3CX from this soft phone? We are not managing a registration.
