Widen Phone Provisioning Model Field Width
Discussion in 'Ideas' started by uptime1, Dec 22, 2015.
  1. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    31
    Hello, I want the Extensions Phone Provisioning Model field width to be expanded, preferably by at least 50%, please.
    The reason is some custom templates we create necessarily have a longer name to provide contextual description in the filename. For example, right now, I'm scratching my head trying to figure out the difference between quite a few templates. The right side of the template name gets cut off making it invisible in the drop down selector.
    What do you think?
