Wifi config with default T46G template
Discussion in '3CX Phone System - General' started by engin411, Mar 27, 2017.
  1. engin411
    engin411 New Member
    Jul 3, 2009
    172
    3CX, latest version, latest default template, latest Yealink firmware on my T46G phones.
    The Yealink phone, in the little bubble at the wifi settings, says the config line name should include the word "static", i.e. "static.wifi.1.ssid = VOIP"
    The default 3CX template there does not include "static", i.e. "wifi.1.ssid = VOIP"
    Is this a bug or by design? I have all 7 of those wifi parameters configured to exactly match my WIFI, but the phone cannot connect after provisioning. It ask for the WIFI PIN.
    Actually, I tried adding the "static." to the parameter line names, with no difference.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
    may be a stupid question... but you have the BT40 dongle installed?
  3. engin411
    engin411 New Member
    Jul 3, 2009
    172
    No worries. Yes, the WF40 dongle is in the phone. I've tried it with the phone defaulted, provisioned and booted, then insert the dongle and try to connect; defaulted, reprovision, insert dongle, and reboot, then try to connect; default, reprovision and keep CAT6/POE in and insert dongle and try to connect to Wifi. The wifi is working and I can connect to it and use it with my laptop.
    No joy so far for the phones.
  4. engin411
    engin411 New Member
    Jul 3, 2009
    172
    Here is my config as entered into the 3CX template. Is there a mistake here somewhere?
    wifi.enable = 1
    wifi.1.label = Phones
    wifi.1.ssid = VOIP
    wifi.1.security_mode = WPA2-PSK
    wifi.1.cipher_type = CCMP
    wifi.1.password = (13-character password with upper/lower/numbers/symbols, confirmed working on my laptop)
    wifi.1.priority = 5
