WiFi or DECT Phone with Shard Park Extension
Discussion in '3CX Phone System - General' started by peterdallassnp, Oct 26, 2010.
  1. peterdallassnp
    Oct 26, 2010
    Hi everyone,
    I have a client that is using SNOM M3 wireless DECT phones for about 1/2 their phones. They would like to use the new Shared Park Feature but since they don't have the Busy Lamp Fields they aren't capable of this. Do you have any recommendations?
    -Pete
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    The 3CX Call Assistant is great for call handling. The users need ready access to a PC though. Would this suit your requirement?
    Richard Crabb
  3. danoh
    Aug 18, 2010
    56
    Shared parking is not working in the 3cx assistant. I've got a thread open on this.
  4. RichardCrabb1
    Mar 7, 2009
    196
    Danoh,
    Ok I will look at your other thread. Am I correct in thinking that if you use 3CX assistant on its own then all is fine? It will work. But when you use it with phones and the assistant at the same time you have problems?
    Richard Crabb
  5. danoh
    Aug 18, 2010
    56
    I can't get the 3cx assistant to use shared parking slots period. It uses the normal parking orbits (*0 type).
    The update notes for 3cx assistant latest version says that it is able to use shared parking, but no dice.
