wildcards with outbond rules???
Discussion in '3CX Phone System - General' started by intercambio44, Jul 7, 2011.
  1. intercambio44
    Aug 22, 2008
    Exist any characters or "wildcards" that I can use in Outbond Rules?
    My problem:
    Our nacional number format is 0xx yyyy yyyy.
    xx= idendify the city, and if the first y is 6, 7, 8 or 9 than the call is for Mobile.
    I would like to set in Outbond Rules:
    Call to number starting with: xxx6, xxx7, xxx8, xxx9 send to .....
    Which symbole/ wildcard I have to use ($, #, x) ???
    Frank
  2. willow
    willow Member
    Mar 1, 2011
    471
    I dont know of any wild cards, you can however just build a outbound rule for each that you need. the system will match from top to bottom the list that is programmed.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You can list at least several numbers like
    3,6-9
    which means any number starting with digit 3, 6, 7, 8 or 9
  4. willow
    willow Member
    Mar 1, 2011
    471
    ah yes, you can use the dashes and comma's though they will not work for this particular instance. unless of course xxx is always the same number.
