Will a TDM400P Card w/ 4 FXO modules work with a 3CX server?
Discussion in '3CX Phone System - General' started by kman13, Nov 10, 2011.
  1. kman13
    Nov 10, 2011
    I was planning on deploying and learning Asterisk, but a friend turned me onto 3CX, and now I'm considering it as well.
    I already bought some hardware, (phone, PoE injector, FXO PSTN card) and I was wondering if the card will work?
    I know the phone will, so now I just have a question about the TDM400P Card with 4 FXO modules
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Re: Will a TDM400P Card w/ 4 FXO modules work with a 3CX ser
    The only cards that work are Sangoma with their Netborder Express software.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    About TDM. It is designed to work only with "proprietary" protocol (system depended). It is not VoIP.
    About cards:
    Yes, Sangoma is supported. But it is not "ONLY"
    Beronet produces the perfect solution and it is not "Asterisk hardware"(BTW, TDM is exact this type of the hardware) as it is advertised by some resources in the internet.
  4. kman13
    Nov 10, 2011
    still confused; will it work? or no?
  5. nbailey
    nbailey Member
    Jan 31, 2011
    359
    double check the responses. No it won't.
