Will pay $100.00 for somone to help get our VOIPJET working
Discussion in '3CX Phone System - General' started by Mirzab, Nov 3, 2007.
  1. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Voipjet > IAX, 3CX > SIP, I think you might be SOL :wink:
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    3CX Server is based on the SIP protocol for VoIP calls. Voipjet appears to be solely IAX protocol (suitable for Asterisk for example). The two protocols are not compatible or interchangeable. If you wish to use 3CX, and its the best, you cannot use Voipjet. If Voipjet is absolutely required by you, you must research other PBXs.
    Of course I could be in error, in which case someone will step in soon and correct me :D .
    And I really will not translate "SOL" :oops:
  3. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    You might have to post a link for me to follow - I did a search for Voipjet on this forum and got only two other threads, both indicating Voipjet was being used on an IAX capable softphone, not 3CX. Sorry.
  4. erich_richker
    Jun 7, 2007
    10
    What I would do is this
    Voipjet -> Asterisk -> 3CX
    Because you can connect on to the other. :D
  5. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    in this case it's better to continue with asterisk. I dont know if in future versions 3cx will support IAX protocol :)
  6. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    We dont have plans to support IAX. Its best to use a provider that uses SIP...
