Will Viatalk work?
Discussion in '3CX Phone System - General' started by Denny, Dec 22, 2006.
  1. Denny
    Dec 22, 2006
    15
    Looks like I can plug in configs to work on softphones but not sure if will work with 3CX? Anyone get it to work? Thanks
    Says:
    14:48:21.024 Registrar::eek:nRequestRetry: Request retry for <sip:17603003490@75.22.169.234:3344>
    14:48:21.014 Registrar::eek:nRequestRetry: Request retry for <sip:17603003490@75.22.169.234:3344>
  2. spamoni
    Feb 15, 2007
    20
    viatalk
    yes,
    I am a viatalk customer and was able to register, make and receive calls.
    If you go into the viatalk customer panel and get the softphone configuration, then use the information there to setup the Line, you should be okay. Do not set it up like Asterisk, as it is not needed.
    Also note: once you create the line to use, you will need to go into it and set the login information in the detail area.
