Win 10 Mobile**[SOLVED]
Discussion in '3CX Phone System - General' started by pcepbx, Jun 24, 2016.
  1. pcepbx
    Apr 7, 2016
    19
    Will the existing Win 10 Mobile client continue to work with V15?
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Re: Win 10 Mobile
    It will register as a sip client - but it will not connect to presence server.
    We will fix it - but unfortunately it will have a very low priority.
