WIN 2008 RC2 - 3CX v9 - IIS
Discussion in '3CX Phone System - General' started by dactor, Jan 5, 2011.
  1. dactor
    Jan 5, 2011
    Hello
    We are trying 3CX which seems to be a great software. The problem we are facing after installation is that when we try to connect to the administration panel (control panel) from the web http://xxx.xxx.xxx.xxx:5484 we get the following link as the default one:
    http://XXX.XXX.XXX.XXX:5484/(S(oxf3ckjrtkx1fanlaptesc45))/ivr_start.aspx
    our IIS is version 7 and have other websites on it with no problems (ie. sharepoint...etc).
    the page even looks like code:
    QUOTE:
    <?xml version="1.0" encoding="utf-8" ?>
    - <vxml version="2.0" application="root.vxml">
    - <!-- Parametrized variables
    <var name="from" expr="'unk'" />
    <var name="to" expr="'unk'" />
    <var name="menu" expr="'unk'" />
    <var name="isid" expr="''" />
    - <!-- Calcualted vars
    <var name="ivr_menu_type" expr="'invalid'" />
    <var name="from_type" expr="'line'" />
    <var name="ext_len" expr="3" />
    <var name="ec_prompt" expr="'EMPTY'" />
    <var name="dr_link" expr="'dr.aspx'" />
    <var name="caller_name_audio" expr="''" />
    - <!-- Insert here
    <var name="ext_pin" expr="''" />
    - <form id="main">
    - <block>
    <goto expritem="ivr_menu_type" />
    </block>
    - <block name="invalid">
    <audio src="GetPrompt.aspx?id=NOACTPERF" />
    <disconnect />
    </block>
    - <block name="end_call">
    <audio expr="'GetPrompt.aspx?id='+ec_prompt" />
    <disconnect />
    </block>
    - <subdialog name="vmail_menu" srcexpr="'LoginVmail.vxml'">
    <param name="vmbox" expr="from" />
    <param name="vmpin" expr="ext_pin" />
    <param name="ext_playcid" expr="ext_playcid" />
    <param name="ext_playdt" expr="ext_playdt" />
    - <filled>
    <disconnect />
    </filled>
    </subdialog>
    - <subdialog name="queue_menu" srcexpr="'QueueMenu.aspx?qdn='+to">
    - <filled>
    <disconnect />
    </filled>
    </subdialog>
    - <subdialog name="dr_menu" srcexpr="dr_link+'?dr='+menu+'&to='+to+'&from='+from">
    - <filled>
    <disconnect />
    </filled>
    </subdialog>
    - <subdialog name="rec_menu" srcexpr="'RecVmail.vxml'">
    <param name="extension" expr="to" />
    <param name="caller" expr="from" />
    - <filled>
    <disconnect />
    </filled>
    </subdialog>
    - <subdialog name="make_call" srcexpr="'MakeCall.vxml'">
    <param name="to" expr="to" />
    - <filled>
    <disconnect />
    </filled>
    </subdialog>
    - <subdialog name="boom_caller" srcexpr="'BoomCaller.aspx?to='+to+'&from='+from">
    <param name="caller_name_audio" expr="caller_name_audio" />
    - <filled>
    <disconnect />
    </filled>
    </subdialog>
    - <subdialog name="boom_acceptor" srcexpr="'BoomAcceptor.aspx'">
    <param name="from" expr="from" />
    - <filled>
    <disconnect />
    </filled>
    </subdialog>
    </form>
    </vxml>
    UNQUOTE
    it seems also we can not find the directory that 3CX installed itself on IIS 7?
    Please can someone assist us.
    Regards
    Ray
  2. paul1
    Jan 14, 2010
    80
    You probably want http://xxx.xxx.xxx.xxx/management
    IIS does not use the same port numbers as Abyss.
    Take a look at c:\ProgramData\3CX\Data\Http.
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    With Cassini abyss: http://XXX.XXX.XXX.XXX:5481/
    With IIS: http://XXX.XXX.XXX.XXX/management
    Cassini Abyss port 5481 not 5484
