Window 7 installation fail
Discussion in 'Windows' started by zenax, Jan 25, 2012.
  1. zenax
    Jan 25, 2012
    I can't install the client free version in Windows 7, due to an unspecified error just after installation launch and after message "Please close 3CX Phone before installing/uninstalling 3CX Phone".
    Any clue?
    Thanks.
    10,754
    286
    Not sure if this is the same issue as it's Win XP related...http://www.3cx.com/forums/problem-installing-3cx-voip-phone-on-windows-xp-19859.html#p102438
  3. efounco
    efounco New Member
    Sep 28, 2011
    148
    Reboot. Then, try right clicking on the executable and running it as Administrator.
    No idea if this will help, just stabbing...
  4. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Search for logs in windows event viewer. Maybe you will find any clue for whats failing.
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    are you using windows installer 4.5?
