Windows 10 latest client Voicemail Play back
Discussion in 'Windows' started by techlogik, Jan 28, 2016.
  1. techlogik
    Jan 28, 2016
    When you click on the voicemail to Play, it opens up a Save As dialog and wants to save the .wav file to a location on the computer?
    Is that normal? Odd...why can't it play the voicemail?
    10,360
    226
    It might have something to do with the format of the file (ADPCM?), and the application that will play it. Is there one available, has it been set to play that type of file?
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,252
    63
    All the Voice Mail wav files are stored on the server. The "Play" button gives the options to download it from the server and play locally on your PC and the "Play on Phone" will ring you you back on your extension from the system and play the message for you without saving it locally.
  4. coreybrett81
    Nov 11, 2016
    35
    7
    Attn: 3CX developers- We need normal PCM back ASAP! This is a real buzz kill for Google Apps customers.
