Windows 2008 64bit support
Discussion in '3CX Phone System - General' started by blackraven, Dec 28, 2009.
  1. blackraven
    Dec 28, 2009
    hey there.
    i like to know is there is any support for this system for the server.
    i use to a dedicated windows 2008 64bit server and anytime i run the setup it tells me the setup package is corrupted. even if i redownload it.
    maby its not supported?
    thanks a lot and best regards
    blackraven
  2. comresource
    comresource Member
    May 22, 2009
    303
    I have 3CX running on 64 bit 2008 with no issues. Both 2008 and 2008R2.
