Windows 7/8
Discussion in '3CX Phone System - General' started by IgorVel, Sep 10, 2013.
  1. IgorVel
    Sep 10, 2013
    5
    Good day!
    I have installed 3CX Phone System RC 12 on Windows 8 and 3CX Phone 12 on Windows 7. 3CX Phone is successfuly registred and I can make calls, but no history, and no any entry in PhoneBook, no extension status. I try reinstall 3CX Phone System 12, install 3CX Phone System 12 on Windows 7, install 3CX Phone System 12 and 3CX Phone 12 on the same system and so on, but no result. Where is may be a problem?
    Regards,
    Igor
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Could be limits of Free mode.. try the demo license.
  3. IgorVel
    Sep 10, 2013
    5
    Problem in antivirus software. After disabling antivirus sw all functions in 3CXPhone work.
