Windows 7 issues after 3CX Assistant uninstalled
Discussion in 'Windows' started by mcbsys, Feb 23, 2012.
  1. mcbsys
    mcbsys New Member
    Oct 8, 2008
    191
    17
    I uninstalled 3CX Assistant 9 from a Windows 7 SP1 Professional machine a couple months ago. Suddenly this past weekend, the "3CXPSTAPI.tsp_unloaded" module started crashing TAPI (error at bottom of post), and whenever it crashed, it brought down several other services and caused Windows to lose authentication. I've posted the details here:
    Windows 7 Issues after 3CX Assistant Uninstalled
    That post includes updated manual uninstall instructions. The most critical step is to run this command:
    regsvr32 /u C:\Windows\System32\3CXPSTAPI.tsp
    I hope that helps anyone else experiencing this problem. I also hope that 3CX has updated the uninstall to really uninstall!
