Windows 7 x64RTM & Outlook 2010 TP
Discussion in 'Windows' started by Sepp1945, Aug 24, 2009.
  1. Sepp1945
    Aug 24, 2009
    I have also problems with TAPI, and can't select the 3cx softphone in the dialog, it is not there.... any idea, by the way i have disabled UAC... no change
    when I loaded the assistant Outlook installed the interface, but it called the extension instead a outside number... eg (075446xxxxx@192.168.1.20) and should have been (075446xxxxx@skymesh.net.au), after uninstalling the assistant the plug-in was missing.
    I am using the demo 2 call version (enterprise) and client 3.1.8571.0
    Thank you very much
    Sepp
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    I don't think the system is ready yet to work with Office 2010, I've run into a lot of technical complications with Exchange 2010, and Outlook 2010. If I find a work around, I will let you know tho.
  3. Sepp1945
    Aug 24, 2009
    Thank you very much
    Sepp
