Windows 8.1
Discussion in '3CX Phone System - General' started by cjtrevor, Nov 19, 2013.
  1. cjtrevor
    Feb 9, 2012
    61
    Has 3cx v12 SP2 been tested to work on Windows 8.1 ?
    We are successfully running on Windows 8 but I just wanted to check before doing the update to 8.1. Or I won't apply the update if it hasn't been tested.
    Many thanks
    Chris
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Better wait for SP3, announced to be available before the end of the month.
  3. cjtrevor
    Feb 9, 2012
    61
  4. Banberry
    Jun 30, 2008
    It also not work with IE11 (Windows 7).
    So we are waiting for SP3...
  5. eagle2
    Apr 27, 2011
    1,085
    11
    Usually Friday evenings, so hopefully tomorrow (29-NOV) or next Friday (6-DEC), but announcement was till the end of month (November).
  6. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    works fine with IE11,just use compatibility mode in the browser
  7. Banberry
    Jun 30, 2008
    Update SP3 didnt help me. But applying compatible mode solved the problem whit IE11.
    Thanks lneblett!
