Windows client not dialing out since today
Discussion in 'Windows' started by das, Jan 2, 2018.
  1. das
    das
    Dec 8, 2015
    14
    Client 15.5.7262.2 running on Windows 7 64 bit.
    Incomminig calls run fine (local as well from outside). Other internal phones work fine.
    When dialing a number (in this case local 200) it shows Dialing but screen is empty (not showing no. 200):
    After some time it runs in a timeout
    Also uninstall and reinstall client does not resolve the issue.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,302
    530
    Hello @das
    Do you experience this issue when dialling all numbers, even system extensions? Try dialling *777 and see if that works. Did anything change on the PC or the network that might have caused this ?
    Do other clients experience the same issue?
  3. das
    das
    Dec 8, 2015
    14
    Hello Yiannis,
    It does not matter if dialing internal or external numbers.
    Same with *777...
    Nothing was changed on PC or network in the last days. Last Friday it was working fine but since yesterday it did not work.
    It is same issue on my laptop - it receives calls but cannot originate calls.
    Also activity log of 3cx shows no entries regarding these calls.
    Meanwhile I rebooted the 3cx host (Windows 10) and the issue is resolved at this time. BTW. nothing was changed at the host and last updates were installed on 14th Dec. and all was fine until 30th Dec. - no one was working until 2nd Jan.
  4. YiannisH_3CX
    May 10, 2016
    7,302
    530
    Glad the issue is now resolved. Please keep an eye on it and let us know if this happens again so we can further investigate.
  5. Aidaca
    Dec 16, 2017
    5
    I am having the same issue. Windows clients and webclients will not dial out. Soft clients on smartphones are working fine.
  6. Aidaca
    Dec 16, 2017
    5
    A reboot did not resolve my issue
  7. YiannisH_3CX
    May 10, 2016
    7,302
    530
    Hello @Aidaca
    Did this stop working or it never worked? Are the clients local to the server or is the server in a remote location? Do you get an error message? Do you see any errors in the activity log?
  8. Aidaca
    Dec 16, 2017
    5
    It stopped working. However, about 2-3 hours after the reboot, I re-provisioned my extensions and now it is working.
