Windows client - options when computer locked
Discussion in 'Ideas' started by PaulD, Aug 7, 2016.
  1. PaulD
    Jul 4, 2010
    78
    8
    Please could the client detect when the workstation is locked (user has selected 'Lock this computer') and take some action pre-defined under Advanced settings?
    Options might be to set a selected profile/status or maybe to unregister. The original state should be restored when the user unlocks the computer.
  2. Tertius
    Feb 24, 2016
    43
    The 3CX Phone API can do all sorts of things for you at different events you would create. So if you're able to code in .NET or know of someone who can then I'd suggest that would be the quickest path to your goal.
    I do agree with you 100% though, why would a phone client be available if the workstation is locked?
    Good Luck!
