Windows Dual Port Headset or Splitter
AnthonyH
Forum User
Is there a way that two headsets can be used via the Windows app so that new staff can sit with an agent and listen to calls for training purposes? Or will this only be available by using a phone with both headset and handset options?
Anthony
I suggest to make a new extension on another PC and through wallboard barge in/listen into a call as two headset cannot simultaneously work on the same machine.
Thank you
I agree with Marios, however if you do have 2 Sennheiser Headsets eg. DW PRO or DW Office, then you will be able to pair the listner´s headset to the users Base, by inserting for 2 sec. When he /she is done listning, just take the headset back in own base for 2 sec.
Reactions: Marios Neophytou
dual jack splitter can also used if the headsets are wired but for me the most reliable solution is barge-in/listen
Reactions: jed
Get 3CX - Absolutely Free!
3CX
