Windows Home Server 2011
Discussion in '3CX Phone System - General' started by dreamscape, Nov 24, 2011.
  1. dreamscape
    Feb 8, 2011
    15
    Apart from the fact that it's not listed on the system requirements, Is there any reason why 3CX v10 would not work with WHS 2011 on the basis that is a scaled down version of server 2008?
  2. Elysium
    Jan 21, 2008
    17
    I had 3CX installed and running on my Windows Home Server 2011 Release Candidate and I had no problems running it.
    I didn't try it on the RTM version that I use now, but I guess there should be no problem either.
    I even installed Zune client on the WHS 2011 which can only be installed on specific OS and Microsoft strictly check that. It's just a few tricks how to install it. That’s all.
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    if it isn't here, it isn't supported. http://www.3cx.com/blog/docs/supported-windows-versions/
    Thanks,
    Nate
