Windows Home Server - Assistant Server CPU usage
Discussion in '3CX Phone System - General' started by sdp, Feb 27, 2010.
  1. sdp
    sdp
    Jan 19, 2010
    Today I found in the TaskManager that the 3CS Assistant Server is using up to 55% CPU while it is sitting there and is doing nothing (no assistants logged on).
    After a restart this stays the same.
    I have installed the 8.0 version of the phonesystem to do some experiments at home.
    It is running on Windows Home Server.
    Any ideas?
    Marcel
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,934
    250
    Re: Assistant Server using much CPU
    Well for sure Windows Home server is not a platform we run tests on, so its best to use a regular Windows
  3. Cjay
    Cjay New Member
    Feb 24, 2007
    190
    Which v8 version are you running? I noticed a big difference between an earlier v8 version (can't remember exactly which) and the current release. The CPU usage was so high on an earlier version that I had to stop the process (well I do run on a relatively lightweight hardware platform). Current v8 release is fine and CPU is back to almost 0%.
  4. sdp
    sdp
    Jan 19, 2010
    De exact version is 8.0.10116.83.
    As far as I now the latest published version.
    And WHS is just a Win2003 OS with some extras.
    So in my opinion a regular OS.
    Marcel
  5. Cjay
    Cjay New Member
    Feb 24, 2007
    190
    Latest build is 8.0.10824 (29 Jan 2010), 10116 was 26 Nov 2009. It would be worth trying to update.
    (though I am using XP Pro, not WHS)
